21 - 40 of 162 Posts
I also have a seat set for someone if they want it. Although I'm having some trouble getting the seat belts out without damaging surrounding parts, and I would also like the persons' plastic covers to replace the seat backs. Just send me a PM and an offer. I would prefer not to ship the parts (but if I must then so be it) as they are kinda bulky and may be expensive. I am in MD near AAFB if it helps.
Cyber Grey EXT CAB Jet Black Cloth Seats
Tinker
I even have a Browneye inspired platform to go with...
I had a feeling that it would not be long before someone tried to take the rear seats from the extended cab - thanks for taking the jump and the photos.
It really looks rather good without the seats. Just need a little carpet or a mat to cover up the two seat mounting holes in the carpet.
I had my extended cab built without the rear seats. I had to get full length black vinyl instead of carpet but I think it was worth not having the munchkin seats behind me. Just wish the floor was flat.
Yeah thanks, I'd be doing this too if I owned one now. Hoping GM sees the light and offers a delete option or just redesigns the seat to be similar to a Gen 1 Colorado ext cab.
I am assuming you looked either online or in person at a factory rear delete. They have a large plastic platform that covers the area. I need to look again at what is done in the backrest area, but my idea would be to think about ordering whatever GM uses on the delete trucks.
Your pics make me think I could do something better than the plastic platform. Maybe use the bar as a start to make some sort of containment wall, with some sides that would attach to the floor in the studs where the belts attach.
I want to say the delete trucks still have rear belts? I will look again.
No rear seat belts on mine.
I just finished removing the back seats from my LT. Easy. The extra depth for storage will come in handy, especially since the wife and I have our seats the entire way back.
Now I have to find a place to store the seat base and seats.:surprise:
Hey folks, New to the forum. I used to have a 2006 Colorado, I now have a 2015. Picked it up Friday afternoon, had the seats out and replaced with plywood by dinner.
I left in the metal support bar and used it along with a 2x4 and scrap wood for some hight and level it when resting on the baby seat anchors. I also did it so I could have a bit of starage for things, I used 4 caragge bolts to hold that all together on the metal bar and then small pieces of metal strapping around the baby seat anchors. It is extremely sturdy now and the dogs / my fishing gear love it haha.
Does anyone know if there are plastic pieces available for where the seats and the Jack went?
Yes, there is a plastic back for the base trucks or work trucks which would cover it entirely. I've seen it here on another thread. You could probably order it from your dealer. I'm thinking of doing something similar.
I was curious how you got the seat backs off?
There are two small hex head screws at the base of each seat back after those are off I believe you just need to slide the back up and it pops off.
since that picture I have also remove the bare metal bracket that the seat back is held up by (the cable loop was really bugging me) to do that first you need to take the black plastic pieces out that the head rest bars slide into. They come out by pinching together the bottom of them and pushing up. do that for both clips on each side, then simply remove the 3 bolts that are holding the brackets on.
Thanks for the instructions for the removable, you will save me some detective work. Don't have my Canyon just yet, but I plan on repeating the same set up as on my 2010 Ext. Cab. I just removed everything tonight, so I took some pictures of my previous set up.. rather simple.
Loaded
Toolbox drawer
Base
What was actually in the cab
Ignore the first 2 bins.. they were actually my console
I would just have the dealership take them out before you pick up the truck.
Where is the fun in that? Plus it would ruin my rep, my neighbours already think I nuts because they always see me ripping into a new truck shortly after getting it.
Looks like you have plenty of tools for the job. Get -r- Done. I'm an apartment dweller so the tools and knowledge are limited for such tasks. I had my truck built without the munchkin seats and therefor they also did not carpet the floor but instead put black full length vinyl on the floor. You can see where they made straight cuts to fit it around the front seats. I look for this to curl up from the extreme heat inside the truck in a couple years. You can feel and see white foam all under the vinyl. It has allot of give to it when you put weight on it. I wished I would of got the truck built with them in there now. Had a dealer tell me it also hurts the trade-in value because most people want the seats in the truck. Oh well..
Do you have any photos of the seats removed, as I want to do this with my new truck? How are you doing by the way? Good evening Sir. I don't think you need to worry about extreme heat considering how far north you are and how your doors will freeze shut in a couple months. What do you think?
