Proper Gear Oil for 2015-16
31K views 18 replies 10 participants last post by  sohccammer427
I want to change the front and rear diff oil at 10,000 kilometers. I emailed Amsoil and asked if the Long Life 75W90 gear oil I have would be ok. The reason I asked this question is because they don't have a recommended product on their web sight for this truck which I found rather strange. They emailed me back and said "no" I could not use their gear oil in this truck because they didn't know if their oil meets GM's production spec 9986285. So I searched the web and found only two oils that meet this spec, AC Delco Dexron LS and Red Line 75W90. In the owners manual it gives two part numbers for the 75W90 gear oil which is the Dexron LS 75W90 gear oil. The part numbers are 88863089 US and 88863090 Canada. Being in Canada I was feeling kind of special that we would get our very own part number. Well I ordered 4 bottles of this stuff and I don't feel special now because what I got was relabled US quarts with bi-lingual labels. They just stuck the French labels over the US labels. So the oil is not a different formulation for Canada, all it is, is a different label. Big deal. Any way I thought I had better use GM's oil, I paid about the same as I would have for the Red Line, and if there was ever a problem GM couldn't say I used the improper oil. I have about 1200 kilometers to go before I hit the 10,000 and then we will change it out. I will drain it into a clean pan just to see what it looks like. And by the way this oil is made for GM by Petro Canada right here in Calgary and you can't buy it from them they just refer you to a GM dealer. They say it is a full synthetic so it should be good stuff, at least I hope it is.
I bet Amsiol hasn't updated there computer for this truck yet. It will probably be updated soon. I'll be using there severe gear in mine.
I emailed Amsoil and asked them about this. They told me they have not tested their gear oil against GM's new Dexron LS spec to see if their product meets the spec. In the mean time they won't recommend their oil until they are sure it's ok because they don't want to jeopardise anyones warranty. You guys can use what ever you want. All I have done here is pointed out that the part numbers in the owners manual point to the Dexron LS 75W90 Gear oil that meets GM's new production specification 9986285. Also if you don't use an oil that meets this spec and you have a problem you might not have any warranty. Again you can use what ever you want and take your chances. I can't and you can't know if there is something different about the diffs in these trucks that may not like the oils that are out there now. There are lots of really good gear oils on the market but they might harm something in the diff that we don't know about. If you can find another gear oil that specifically states it meets GM's spec 9986285 let us all know.
I'm curious if anyone has changed their Front &/or Rear Diff fluid yet?
If so did you use an alternative gear oil such as Amsoil or did you just go with the GM's 75W90 gear oil (Dexron LS gear oil production spec 99862865)?
#11 ·
I changed mine out to Amsoil severe gear not to long ago, Both diffs quiet as a mouse, seems even smoother at speed. I ordered new diff plugs which were about 8.00 as the plugs were already coated with thread sealant. Both bottom plugs are magnetic as well, both front and back are the same plugs....
As someone noted, the 2016 Colorado owners manual only calls for "SAE 75W-90 Axle Lubricant". My 2011 Corvette Grand Sport owners manual specifically calls for "DEXRON® LS Gear Oil". I agree with the earlier assessment that the spec is SAE 75W-90 Axle Lubricant. Nothing more. We'll just say my front and rear diff were changed at 1000 miles.
#9 ·
I assume the Vette has a limited slip diff? Hence the requirement specifying "LS Gear Oil". I don't think the Eaton E80 requires that additive & I would guess any good quality SAE 75W-90 Axle Lubricant would be fine.
I'll probably go with Amsoil when I do mine.
#10 ·
Yeah the Vette has a limited slip and they did have some major diff clutch pack chatter issues with the early models thus the later release of the GM spec Dexron LS fluid which I religiously use in it only as it is rather pricey... :wink2:
Reactions: CrashFix
#14 ·
And those diff plugs do a good job collecting break-in debris, here what mine looked like after a recent fluid change (Used Amsoil & have 20K on the truck). The last set of plugs are from the transfercase, they both come with no magnet but I epoxied a magnet to my drain plug as can be seen in the photo.
#16 ·
CFans... Just to double check. I found no info in the owners manual or diesel supplement for the read differential gear oil. So what weight, 75w-90 or 75w-140 does it call for?
I'm zeroing in on 20,000 miles and want to replace it.
Thanks
#17 ·
Dealer tried to (he did) sell me synthetic gear oil for my G80.
I got suspicious about it and did some research.
My manual (2018) calls for GM Part No. 88863089, which is mineral based.
I don't know if I can use synthetic in my G80.
If the G80 seals are rated for synthetic, I can use syn and my fluid will have longer life.
If not, or if I don't know, I need to stay with the mineral.
#18 ·
Mobil 1 synthetic gear oil is compatible with all limited slip differentials and meets/exceeds the GL-5 requirement. It is pricey, compared to non-synthetic, but like all synthetics will flow better at lower temps which can aid in fuel mileage, though I don't know to what degree. But in Antarctica (or even the misspelled Antartica), low temperature flow characteristics should be important.
#19 ·
