I was curious if 2021's have the latest Mobil ATF, or is GM just offering this as a solution in the event of a problem?
No, all 2020+ models should have the correct, updated HP fluid. The TSB (https://static.nhtsa.gov/odi/tsbs/2019/MC-10163890-9999.pdf) applies to 2017-2019 model years with the 8L45 8-speed. If owners ignore the shudder then it can lead to more problems, but addressed early on it should only involve a fluid exchange to get the new fluid in.So all 2018+ models should have the correct fluid? What about those members with 2018+ models complaining about shudder? Is it more than just the fluid?
As of July 8th, 2019, GM began using a new type of Mobil 1 automatic transmission fluid for the troublesome transmissionsSo all 2018+ models should have the correct fluid? What about those members with 2018+ models complaining about shudder? Is it more than just the fluid?
Ok but read page 6. On flush machine setup. It says...It was said in the TSB.
"Important: This procedure must be followed as published. The exchange process is required to obtain proper level of new blue label Mobil 1 Synthetic LV ATF HP fluid."
https://static.nhtsa.gov/odi/tsbs/2019/MC-10161881-9999.pdf
The 2018 and 2019 used the HP Fluid and not Dexron VI like the 2017. Blue Label was the replacement for them both.Ok but read page 6. On flush machine setup. It says...
"Initial TransFlow Flush Machine Setup Important: The prepping procedure only needs to be completed if the DT-45096 supply reservoir has DEXRON VI fluid in it and has not been converted to use the new blue label Mobil 1 Synthetic LVATF HP fluid. Note: The prepping procedure only needs to be completed if HP fluid is not in the supply reservoir."
I thought they went from black label to blue label. Dexron VI was before the black label? I read that the black label is compatible with blue if you don't get it all out on a drain or flush. It only mentions Dexron VI. Doesn't say to prep the flush machine from black to blue label. So what I'm trying to figure out is at some point was Dexron VI used in the 8 speed early on and then swapped to the black label and now blue label? I know GM hides information to the consumer for privacy reasons.
Now it is also possible that the flush machine was previously used to flush transmissions with Dexron VI hence the notation on flushing the machine. But you would think there would be a notation about black label being in the reservoir and how to address it before using the blue label. Ok, that's it for now.
For more clarification:Ok but read page 6. On flush machine setup. It says...
Actually you gave me the answer I was hoping for. At some point the 8 speed had Dexron VI. I'm trying to verify compatibility. If my shudder doesn't clear up after repeat draining and adding new fluid then I will switch over to the blue label Mobil 1 fluid. I just turned 13,000 miles. I doubt my TC is glazed or shot. I don't drive much on the highway.The 2018 and 2019 used the HP Fluid and not Dexron VI like the 2017. Blue Label was the replacement for them both.
Sorry that it gave you some confusion
Torque Convertor being the issue itself is less likely. Usualy will be fluid issue. And that is true for all the manufactures out there nowActually you gave me the answer I was hoping for. At some point the 8 speed had Dexron VI. I'm trying to verify compatibility. If my shudder doesn't clear up after repeat draining and adding new fluid then I will switch over to the blue label Mobil 1 fluid. I just turned 13,000 miles. I doubt my TC is glazed or shot. I don't drive much on the highway.
Your 2019 diesel doesn’t have an 8 speed. Did you switch trucks to a V6?Actually you gave me the answer I was hoping for. At some point the 8 speed had Dexron VI. I'm trying to verify compatibility. If my shudder doesn't clear up after repeat draining and adding new fluid then I will switch over to the blue label Mobil 1 fluid. I just turned 13,000 miles. I doubt my TC is glazed or shot. I don't drive much on the highway.
Thanks for that information. No, I have a diesel with the 6l50. That is why I am trying to get as much information on different ATF fluids to try to solve my TC shudder. I'm in the process of doing several dump and flush and then see if that helps.Your 2019 diesel doesn’t have an 8 speed. Did you switch trucks to a V6?
Old thread but thought I'd hop in here as my new-to-me truck is in the dealer for shudder, and I just spent some time with their transmission tech assisting with diagnostics. 2016 2.8 with 6l50, truck is already on its second TC (first replaced at 40k miles). I bought it at 48k miles and has significant shudder now at 50k.Thanks for that information. No, I have a diesel with the 6l50. That is why I am trying to get as much information on different ATF fluids to try to solve my TC shudder. I'm in the process of doing several dump and flush and then see if that helps.
Yes the 6 Speed and the 8 Speed take two different types of Transmission Fluid.Old thread but thought I'd hop in here as my new-to-me truck is in the dealer for shudder, and I just spent some time with their transmission tech assisting with diagnostics. 2016 2.8 with 6l50, truck is already on its second TC (first replaced at 40k miles). I bought it at 48k miles and has significant shudder now at 50k.
I asked the technician who seemed quite knowledgeable, and he strongly stated that the 6 speed and 8 speed transmissions are very different, and the 6l50 should only ever run on dexron 6. The 8l's should only ever run HP. They are doing a new TC and changing the fluid out to Mobil 1 synthetic dexron 6 (not blue label HP). I imagine going to synthetic will help my new torque converter last longer, and I'm not one to go explicitly against GM parameters for fluids on my newish truck. On my vintage Porsche or 10 year old race car, sure lol.
That said, if the shudder comes back again some day on my third torque converter, and Shudder Fixx doesn't fix it, I may swap to the HP
OP, what did you end up going with?
My 2016 Colorado Dmax transmission was never just right from new. At almost 60,000 miles it took a turn for the worse. No shudder, but 2-3 and 3-4 shifts were terrible. Extended warranty was still in effect, so I turned it over to the selling dealer. Six weeks later it was back with a new valve body.Yes theh 6 Speed and the 8 Speed take two different types of Transmission Fluid.
In that 60k miles had the fluid ever been serviced? Did you tow or do frequent low-speed/off-road driving? Even replacing oxidized OEM Dex6 with fresh Dex6 results in a big improvement if your fluid is starting to get trashed, I noticed the same when I had my fluid serviced for the first time at 46k miles. Shifting wasn't bad, but I was starting to experience a harsh downshift when slowing to make turns from one street onto another. Trans shifted better than new after the service and has been perfectly fine since then (with regular fluid changes). I'm at 90k now.My 2016 Colorado Dmax transmission was never just right from new. At almost 60,000 miles it took a turn for the worse. No shudder, but 2-3 and 3-4 shifts were terrible. Extended warranty was still in effect, so I turned it over to the selling dealer. Six weeks later it was back with a new valve body.
Shifts were better but still not good. About a month later I changed the transmission filter and used Mobil 1 synthetic fluid. The improvement was immediately noticeable and improved for several days thereafter.
I can't attest to the long-term results as I sold that truck after driving it for another 10,000 miles. The shifts continued to be better than when new. Other than the fluid, the only other variable was the new filter.
I purchased one of the last 2022 Canyon AT4's with the same powertrain. Needless to say, at around 10,000 miles my GMC will receive the same treatment.
I serviced the transmission following GM specs, so no service. I pull a 3,000 lb. trailer once a week in the summer. Approx. 20 miles round trip. Country roads only. I almost never drive in a town, much less a city.In that 60k miles had the fluid ever been serviced? Did you tow or do frequent low-speed/off-road driving? Even replacing oxidized OEM Dex6 with fresh Dex6 results in a big improvement if your fluid is starting to get trashed, I noticed the same when I had my fluid serviced for the first time at 46k miles. Shifting wasn't bad, but I was starting to experience a harsh downshift when slowing to make turns from one street onto another. Trans shifted better than new after the service and has been perfectly fine since then (with regular fluid changes). I'm at 90k now.
