Ok but read page 6. On flush machine setup. It says...
"Initial TransFlow Flush Machine Setup Important: The prepping procedure only needs to be completed if the DT-45096 supply reservoir has DEXRON VI fluid in it and has not been converted to use the new blue label Mobil 1 Synthetic LVATF HP fluid. Note: The prepping procedure only needs to be completed if HP fluid is not in the supply reservoir."
I thought they went from black label to blue label. Dexron VI was before the black label? I read that the black label is compatible with blue if you don't get it all out on a drain or flush. It only mentions Dexron VI. Doesn't say to prep the flush machine from black to blue label. So what I'm trying to figure out is at some point was Dexron VI used in the 8 speed early on and then swapped to the black label and now blue label? I know GM hides information to the consumer for privacy reasons.
Now it is also possible that the flush machine was previously used to flush transmissions with Dexron VI hence the notation on flushing the machine. But you would think there would be a notation about black label being in the reservoir and how to address it before using the blue label. Ok, that's it for now.
