Don't believe I have the results around anymore but pulled UOA on dealer supplied GM dexos1 (prepackaged quarts) oil at 5k miles, additive pack was essentially used up and blackstone didn't recommend running it to the 7,500+ mile factory drain interval. Next oil change was at 7,700 miles, Amsoil and additive and wear metal #s improved. 3rd OCI was ~7,700 miles running Penzoil Platinum, comparable #s to AO. All three were same weight, same filter PN.
Oil isn't oil, all additive packages aren't created equally.
I tell everyone if you're going to run extended drain intervals you should pull some UOAs.
Years back a coworker ran 10k intervals on his old 12V cummins. Pulled UOA at 7500, always good, and went to 10K for even #s.
Just my anecdotal "evidence".
