I tried these in early 2015 check out my link here so you don't go down that hole.
https://www.coloradofans.com/forums...gen-accessories-aftermarket-products/221257-bolt-lock-2015-canyon-colorado.html
It turns out that our keys are too short to work with the Bolt locks. They claim to have made the proper change but I'm still hesitant to try one again.
Here is my correspondence email: (sorry it's out of date order, start at the bottom)
Jeremy,
Our engineers had some more time to dig into the problem this afternoon and your first thought that the key was too short to work with the padlocks was correct. The blade of the key is unfortunately too short to reach all the way to the back of the padlock to successfully code the lock cylinder. We are still looking to see if this problem also exists with the rest of the line of locks or not.
What I can do for you is a couple of things. The first option, I can send the lock back to you that you just sent in and then you can return it to Pep Boys for a refund. The second option is that if you still have the receipt if you could just e-mail me a copy of the receipt I will get a check written for you for the cost of the lock.
Please let me know what you would like to do and I'm sorry that we couldn't get the locks to work with your key.
Regards,
Jason
Jason Buckles
Web Marketing Analyst & Developer
Strattec Security
Phone - 414.247.3673 | E-Mail -
JBuckles@strattec.com
Facebook Twitter YouTube
>>> On 2/17/2015 at 12:15 PM, in message <C4AFB0F76227428C99670DA71C747F46@DellBobcatLT>, "Jeremy Cerveira" <tinker0000@gmail.com> wrote:
Jason, I took the bottom red part off the lock to see if maybe the key wasn’t going in far enough and no such luck (I put it back together). The lock will be in the mail shortly.
Thanks, Jeremy
Sent: Tuesday, February 17, 2015 11:59 AM
To: Jeremy Cerveira
Subject: Re: GM key Bolt Lock help
Jeremy,
I just talked to our engineers and we aren't sure exactly what is causing your problem with the locks, I even coded a lock with a similar key just now and didn't have any problems. I think the best thing for us to do would be to get that lock sent back to us and we can send you out a replacement lock from our stock. Once we have the lock back the engineers can dig into it and find out what is exactly stopping the lock from working.
What is your shipping address and I will get a lock out to you ASAP. You can send the padlock you have back to me at:
Jason Buckles
c/o STRATTEC Security
3333 W Good Hope Rd
Milwaukee, WI 53209
Thank you,
Jason
Jason Buckles
Strattec Security
>>> On 2/17/2015 at 10:42 AM, in message <E08426F6E77B4B16B87127B7227B3F3D@DellBobcatLT>, "Jeremy Cerveira" <tinker0000@gmail.com> wrote:
Jason, The little red tab was in place on both locks. I returned the first one thinking someone messed with it in the store. The second lock doesn’t work either. Please see attachment (picture of my key). Thanks, Jeremy
Sent: Tuesday, February 17, 2015 10:58 AM
To: Jeremy
Good Morning Mr,
I'm sorry for the problems you are having with your BOLT Padlock. I am not aware of any problems at this time regarding coding of the a GM Center Cut Padlock with a Colorado key. The coding process is as easy as it shows in the videos so there should be no reason to put the lock in a vise just to code it.
A couple of questions so I can take some information to our engineers so they can help figure out what the problem is, unfortunately your 2013 Silverado key will not work in that particular padlock. First, was the rubber seal over the key hole still in place when you opened the packaging? Second, would be able to send me a picture of your key blade?
In the meantime I'm going to talk to our engineers to make sure there isn't any known problems with the Colorado keys and our center cut locks.
Thank you,
Jason
Jason Buckles
Strattec Security
>>> On 2/17/2015 at 8:44 AM, in message <CAK4yH9ytXEUfOQER6Hn8+o_=+s7N+CJ3k8eh+os=PSR0v9yMTg@mail.gmail.com>, Jeremy Cerveir <tinker0000@gmail.com> wrote:
Hi, my name is Jeremy and I am I having some issues with one of your locks. I purchased a 7023537AA lock from Pep Boys and I am having a hard time making it work. I purchased one on 2-10-15 and returned it for a new one after not getting it to work. I have a 2015 Chevrolet Colorado with a center cut GM key which measures 1-15/16" long with the cut part extending about 1inch from the end. The videos I've watched on Youtube and your site make it look very easy to turn the key clockwise 1 turn the first time but my key will not turn. I have even tried locking the shackle in a vise to hold the lock and then turn the key but I do not want to bend or break my key off in the lock. I'm going to keep this lock and try a different key, maybe one of our work truck keys (2013 Silverado has a longer shank) will fit. Is there a problem with these keys or are they not long enough to work in this lock.
Thanks, Jeremy
