Has anyone figured out a way to wire a light bar to automatically turn on with the high beams with a 2nd gen? (2018)
That was the idea. If both switches were off the light bar would never come on. Most of the time I’d probably have the on/off w/ high beam switch on so power would only come when high beams on. If I wanted the light bar on at any given moment I’d just hit the override “original” switch circuit. If that switch was on, the light bar was on, regardless of the other button. I hear what he was saying though. I don’t know if there’s any diode in these Apiele switches to stop the relay signal output of the override switch from back feeding into the “high beam” switch and back to the high beam fuse.Yep, like @Tom S. said. But, does it really matter?
Not really. Basically you are turning on the high beams with the override IF the high beam switch is ON. No biggy and maybe a good thing?
