Post up pics, weights, trailer info (make, model, etc), and your hitch/WDH setup if at all possible!
I wouldn't think 200 pounds in bed would be an issue. That means if you pick me up as a rider, I qualify for tow/haul mode.If you're asking me, yeah. I use Tow/Haul for towing the sailboat and any time I'm hauling more than 200lbs in the bed...
It seems to shift better when the weight is over the axle. I dunno.I wouldn't think 200 pounds in bed would be an issue. That means if you pick me up as a rider, I qualify for tow/haul mode.
Not sure where I would draw the line on payload. Probably at least 600 to 800 pounds before I used tow/haul mode. Are these turbos that sensitive?
Downhill to lake usually. Uphill home.Finally got the boat out today. Tow mode used. Weird thing, mpg to lake better than mpg from lake.
Or the boat took on a bunch of waterDownhill to lake usually. Uphill home.
Or you caught some big fish.
Sorry I missed this.Thanks for this write-up its very helpful. Any issues at the boat ramp at all? I'm looking at dragging my 24' boat which combined will be about right about 6,000 lbs with my Colorado Z71 and that's the only thing that concerns me... any slippage all all?
now my truck can look like its owner, with big ears 🤣👌Custom tow mirror extensions are finally available for the 3rd gen twins. Still not as good as real tow mirrors, but simple to install, perfect fit and much better than the universal versions.
Hmmm, those are interesting. Can the outside mirror be tilted down enough to see the rear wheels? I think these might be handy for seeing your wheels before/as/after they go over obstacles. Might not work on narrower trails, but...Custom tow mirror extensions are finally available for the 3rd gen twins. Still not as good as real tow mirrors, but simple to install, perfect fit and much better than the universal versions.
Thats what I love to hear because I want to get a Colorado Trail Boss and tow a 23ft tandem axle toy hauler which should max after being loaded around 5500 to 6000 ibs so I love to hear it tows it great!Upgraded the camper this year So far only pulled it 2000 km this year. But it pulls great 22 feet long 5600 pounds loaded.
Good information .... thank you. I'm on the west coast and pull a 25 ft with my 2024 Canyon Elevation. My trailer is almost exactly the same weights as you mentioned, and like yours, my Outdoor RV Blackrock trailer is very wide comparing with other mid and smaller trailers. I haven't done any trips more than two hours but I also found the truck/trailer combo tracked pretty good. I only have one sway bar with the WDH, but thinking of adding a 2nd one for the other side. Also, for peace of mind, I added air shocks which can be adjusted with a simple bicycle pump. I set them to 20 lbs when towing for that bit of extra control on bumpy, and dirt roads as much of the BC interior has construction going on everywhere. When the tow season ends in late September I set the air shocks to 5 lbs and the ride is pretty good. Surprising, there is no lack of towing power to haul these mid size trailers, so my downsizing from an F150 has been a success.TOWING UPDATE-SUMMER OF 2025.
Just wanted to post a update on towing experience with my 2024 Colorado Trail Boss.
Trailer:
2013 Keystone Bullett 230 BHS
27 ft from ball to bumper
4300 lbs (dry)
5000-5300 lbs loaded (Have not CAT but estimate based on gear we carry)
Equalizer WDH with anti-sway.
Approximately 2500 kms travelled over Newfoundland and Labrador, Canada from late May to August.
Towed all over NL, Canada mainly in northern areas, across central NL and east NL and back. No long inclines but several 6-7% grades lasting several kilometers. Temps were around 15 Celsius (late May) to 35 Celsius in mid July.
I was VERY impressed with the capabilities of this truck towing this camper. No issues at all power wise with the 2.7. Towed in TOW MODE and on hills there was power to spare and merging on to traffic. We do not have a large Interstate here but the Trans Canada Highway and Provincial Highways and speeds were between 90 and 100 km/hr. Very comfortable maintaining speed. I averaged between 12 and 11 mpg depending on tailwind vs. headwind. Don't think I have much to complain about there. The power was there to handle the weight of the camper without hesitation. No issue with transmissions temps, oil or coolant temps.
I don't think I would recommend towing a camper much larger in length. The Equalizer hitch with anti-sway was a must. I did tow it in some windy conditions with gusts in the 50+/kph range and you could feel the truck and trailer move slightly. I did expect this with the shorter wheelbase. Nothing white knuckle, but you had to pay attention (I would drop my speed to 90-95 km/h). In lower wind speeds the truck tracked beautifully. The Bullett has a wider wheel footprint that is said to aid in sway as well. This potentially helped for sure. I would recommend the Equalizer WDH towing any trailer to be honest. It was a simple set up and a very effective system.
Only issue I had was pulling onto a highway I hit the gas pretty hard and I THINK the wheels spun on some gravel? A STABILITY CONTROL error message flashed on and the CHECK ENGINE light came on and the truck bogged down slightly. As soon as I let off gas message went away and truck was fine. Have not replicated since.
Yes, a full size MIGHT be better stability wise but was very impressed after a summer of towing with the power and performance of the Colorado and at no point did I feel "under trucked". Was nervous towing a trailer of this length but with the proper wdh it was a solid set up. Camping season is almost over here on the far east cost of Canada. Already looking forward to next summer!
View attachment 490680 View attachment 490681
THANKS SO MUCH for this confirmation and information on towing a 27ft long RV with a Colorado Trail Boss because that is almost the same size I want to tow with a TB when I get one hopefully in 2027. I will probably get a 21ft to 27ft so it is great to hear that the TB tows it well! I will also get a anti sway weight distribution hitch and air bags to level the trailer and truck when towing since I will probably add a 2 inch front lift/level kit so the air bags should level the nose back down when towing for the best steering control. Thanks so much!!TOWING UPDATE-SUMMER OF 2025.
Trailer:
4300 lbs (dry)
I am looking to get a Colorado Trail Boss in a few years and I would also like to put air bags on it to help with heavy 5,000 to 6,500ibs, (after loaded) RV towing to help level the nose of the truck. What bags did you go with?Good information .... thank you. I'm on the west coast and pull a 25 ft with my 2024 Canyon Elevation. My trailer is almost exactly the same weights as you mentioned, and like yours, my Outdoor RV Blackrock trailer is very wide comparing with other mid and smaller trailers. I haven't done any trips more than two hours but I also found the truck/trailer combo tracked pretty good. I only have one sway bar with the WDH, but thinking of adding a 2nd one for the other side. Also, for peace of mind, I added air shocks which can be adjusted with a simple bicycle pump. I set them to 20 lbs when towing for that bit of extra control on bumpy, and dirt roads as much of the BC interior has construction going on everywhere. When the tow season ends in late September I set the air shocks to 5 lbs and the ride is pretty good. Surprising, there is no lack of towing power to haul these mid size trailers, so my downsizing from an F150 has been a success.
The Equalizer hitch does a very good job of leveling out rear end squat. My posted tongue weight is 435 lbs but with propane and batteries its around 550 lbs or so and I don't think I would need the air bags (My Trail Boss has a 2" from factory I believe). The ride is very poised and level. And yes, I think to invest in a good WDH with sway control (the Equalizers system has anti sway built in) is a must any anything longer than 23 ft or so but any weight between 4500-5500 lbs should be ok weight wise. Obviously where you live in respect to exterior temps, terrain etc., may change the variables from my situation.THANKS SO MUCH for this confirmation and information on towing a 27ft long RV with a Colorado Trail Boss because that is almost the same size I want to tow with a TB when I get one hopefully in 2027. I will probably get a 21ft to 27ft so it is great to hear that the TB tows it well! I will also get a anti sway weight distribution hitch and air bags to level the trailer and truck when towing since I will probably add a 2 inch front lift/level kit so the air bags should level the nose back down when towing for the best steering control. Thanks so much!!
