Status
Not open for further replies.
USB wiring harness
4K views 3 replies 2 participants last post by  luciferi
I tried doing a search for this but was unsuccessful. I just got a 2019 Colorado and really want to relocate my USP carplay connection from my front center console to the armrest slot (mine came with just a cover cap). Is there anyway to either add another carplay USB jack or relocate the front one to the armrest? I do not have the Bose package. I thought I would need a certain wiring harness but cant seem to find any how tos or tutorials. If anyone has any idea I would love to know!Thanks!
On my 2018, the inside console USB port connects to the rear of console dual USB port. The rear dual has a usb cable going in , then a usb cable going out to inside the console. Not sure if your 2019 has the rear dual usb but if you do, pop it out and check the connections.
I do have the dual usb ports, however those are just power and does not connect to carplay. I am wondering if there is an additional output for carplay on the stock head unit or if I could come off the front console usb to add one in the armrest console. I just don't know what wiring harness I will need to do this.
The 2018 Usb goes the radio and to the Hmi. You need to check those for an used port.
If you get a rear console dual port from 17 or 18, you can replace the front one with it and move the front to console. You can use a generic mini usb cable to link the two, it won’t lock but works fine. You will also need the 6 pin connector and run power.
CarPlay compatible USB ports are different from older ones.
Status
You have insufficient privileges to reply here.
