Superlift leveling kit, 1 inch or 2 inch?
365 views 5 replies 2 participants last post by  GrizzlyRent
#1 · (Edited)
Hi I have a 2025 GMC Canyon Elevation. I am wanting to install a leveling kit. I am looking at the Superlift understrut leveling kits that are spacers installed between lower shock mount and control arm. The kit comes in both a 2 inch or 1 inch option. If I am looking to achieve level, which one do I need? Also, does anyone have experience with this particular leveling kit? I’ll link to the kit in question for reference.
I would do a 1” if you don’t want to have “squat” everytime you put groceries in the bed 😁
If you want to double check and get a better rough idea- Park on a flat surface. Take a tape measure from the street up the side of the truck to the top of the wheel well right at the fender on both front and back wheels. The height difference between front to back should be about 1.5” in stock form
Thanks for advice. So sounds like I’ll either be roughly half inch lower or higher than level in front. I will go ahead and take some measurements today to confirm.
I know some kits add some preload. So an advertised 1 inch kit may actually come out to like 1.25 inches of lift. I would assume that this kit, considering it is installed on the bottom shock mount, would be more “true” to the listed lift (1 inch spacer = 1 inch lift)? Maybe not though.
