Just finished replacing my stock speakers in my 2023 LT with Pioneer 6x9s and 6.5s. OEM sounded terrible. I did not have the Bose system. I used some foam weather stripping between components to get a snug fit. Front doors have (2) 7mm under the grab handle trim and (2) on the bottom of the door. Rear doors have (2) 7mm under the grab handle trim and (1) on the bottom of the door. Speakers are held in with a single 7mm and plastic pin. Door snaps back into place, did not need to remove the door panels completely. Took around an hour.
Replaced the door speakers with adapters from amazon:
Front Door Adapter: Metra 82-3004 2014 6X9" Speaker Adapter for Select GM Trucks
Stock 6x9:
6x9 Opening and Plug:
Rear Door Adapter: Scosche 6.5” - 6.75” Speaker Adapters SAGMHR634
Stock 6.5" and Adapter:
Installed 6.5":
Wires: 2 Pair Car Stereo Speaker Wire Connection Harness Plugs Compatible with Select 2010+ GM Vehicles
Amazon.com: Metra 82-3004 2014 6X9" Speaker Adapter for Select GM Trucks,Black : Electronics
www.amazon.com
Amazon.com: Scosche Compatible with Select 2005 to 2020 Buick, Cadillac, Chevrolet, GMC, Hummer, Pontiac and Saturn Vehicles 6.5” - 6.75” Speaker Adapters for (1 Pair) SAGMHR634 : Electronics
www.amazon.com
Amazon.com: 2 Pair Car Stereo Speaker Wire Connection Harness Plugs Compatible with Select 2010+ GM Vehicles - for 4 Speakers Installation - Compatible Vehicles Listed Below : Electronics
Buy 2 Pair Car Stereo Speaker Wire Connection Harness Plugs Compatible with Select 2010+ GM Vehicles - for 4 Speakers Installation - Compatible Vehicles Listed Below: Radio Wiring Harnesses - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
