Speaker upgrades to the "Bose" system
15K views 22 replies 11 participants last post by  BlueZedR2
I have the Bose speakers (at least they have the Bose badge on the dash speaker). They certainly don't sound like it though. For those that have upgraded the speakers, did you upgrade all or just some? I don't want an entire replacement so I was thinking of just upgrading the door speakers since they sound the lease impressive. And what speakers did you use? Thanks!
took 30 seconds
Bose Speaker Replacement? | Chevy Colorado & GMC Canyon
coloradofans.com
https://www.coloradofans.com › threads › bose-speake...
May 6, 2017 — Lots here on Bose speaker replacement. Here is just one .. . there are more. Read through the threads and various owners have used different ...
PSA - Bose dash replacement speakers
Mar 9, 2018
Speaker Upgrade | Chevy Colorado & GMC Canyon
Nov 19, 2021
Speaker Replacements | Chevy Colorado & GMC Canyon
Mar 26, 2022
Bose Upgrade | Chevy Colorado & GMC Canyon
Aug 20, 2023
The doors are dedicated midwoofers with a subwoofer identity crisis. They sound unimpressive because technically you shouldn’t hear anything come out of them at those frequencies.
I reccomend not changing them to coaxial, but it’s your truck so do as you please.
This post has been deleted
#8 · (Edited)
I'm very interested in hearing about this install. My understanding is that the factory Bose system has oddball Ohm ratings which makes it difficult to use aftermarket speakers. The 2nd gen specs are readily available on this forum, but not the 3rd gen. Were you able to find/figure out what the factory Bose specs are? Size, wattage, impedance?
What speakers did you install?
Any need for adaptors or are the factory speakers standard sizing?
What about adaptors for the wiring? Is the factory wiring standard or is there some sort of funky connector?
#9 · (Edited)
Wire and speaker adapters are needed. Check crutchfield for reference for adapter part numbers, then source from your favorite vendor.
Factory Bose speakers are 6x9 (made in mexico) for front doors and 6.5 (made in china) for rear doors. The 3 dash speakers appear to be 2.75". I have not replaced those yet.
EDIT: the Bose ceneter speaker is NOT 2.75", it is larger. I did not measure it.
#14 · (Edited)
not trying to be a Nancy/Karen but
"The Bose doors speakers are dedicated midwoofers with a subwoofer identity crisis. They sound unimpressive because technically you shouldn’t hear anything come out of them at those frequencies."
To exasperate the issue the after market speakers may have an impedance mismatch so to "hear them" you turn the volume up which increases the volume to the dash speakers also.
The rear speakers are to fill in the over all sound, also not to be heard. But some people will install sub and woofers with big amps for the rear
#22 ·
"No highs, no lows, must be Bose!"🤣
  • Haha
Reactions: jim_87 and Stone111
