When I apply the accelerator i hear the sound of water flowing behind the passenger side dash. Like where the heater core is. I thought it may be air in the system so I burped the system. Has anyone else experience this?
I have that problem. What can I do to fix it?When I apply the accelerator i hear the sound of water flowing behind the passenger side dash. Like where the heater core is. I thought it may be air in the system so I burped the system. Has anyone else experience this?
over fill the tank just a bit, drive it, recheck after it cools off.I have that problem. What can I do to fix it?
How many days/times have you done this? You must have a leak.I did that and I have to be filling putting water every two days..
2or 3How many days/times have you done this? You must have a leak.
If you are seeing significant drop in level still after 2-3 times of this, I would think the have sprung a leak.2or 3
2or 3 day one time
No sure I need to check that..If you are seeing significant drop in level still after 2-3 times of this, I would think the have sprung a leak.
Is your oil in crankcase foamy or milky?
Yes, i am having problems with this issue while the dealer is acting like they do not know what is happening....When I apply the accelerator i hear the sound of water flowing behind the passenger side dash. Like where the heater core is. I thought it may be air in the system so I burped the system. Has anyone else experience this?
Have you read the 9 pages of posts here? You might find a solution in this: Fill the reservoir, I suggest about an inch over the actual fill line, and drive it a while. The sound will go away typically.Yes, i am having problems with this issue while the dealer is acting like they do not know what is happening....
just fill it about an inch over the line, easy.Yes, i am having problems with this issue while the dealer is acting like they do not know what is happening....
