Was looking at rough country's new 6" lift but it may be too high for my liking. Has anyone done or seen the 4 or 5 inch so I can see what it would look like? Thanks a bunch!
Here's my 4" liftI have been searching for any pictures of the 4" RC lift and they don't seam to exist. Does anyone have a picture of the 4" RC lift on a Colorado. Thanks
Ahh these guys..the anticipation isn't helping me right now!All information and build will be unveiled at SEMA :smile2:
Well, to his and your benefit, that post is 2 years old...:wink2:Ahh these guys..the anticipation isn't helping me right now!
Like I said before, the 18's will fit on the 4 inch lift with spacers and some modifications to the front of the wheel wells. This involves removing about an inch of plastic from the plastic bracket that reinforces the outer bumper. It's pretty easy to do if you have already removed the air dam.I thought I read here somewhere that some people have done this, can some one confirm for me that factory 18" with spacers will clear or not clear the 4" lift.
Thank you.
Yes I have Helo wheels. I think my back-spacing is 2.5 inches. I had my lift done through the dealer's source, so I don't know for sure. The edge of the tires stick out about an inch outside the fender sheet metal. (I have the extra-wide flares). I think you are going to need more than 1.5 inches. The most critical thing is probably not the wheel itself but the tire diameter. In my case they are 33.1 inches. The front wheel well is just too small in front to allow the tire to clear. It may drive OK level and until you compress the springs a little you won't notice the rubbing. You will want that spacing to be just right, otherwise the rubbing point will be at the fender flare itself and you will have big problems. Trimming inside the well is a manageable task. The back-spacing definitely prevents rubbing against the frame, control arms etc.Paul, yes I had read your previous posts, actually your pictures is what has persuade me to go with this setup.
Issue I have is I am planning to use factory 18" wheels, you seem to have aftermarket.
I believe the factory wheels have 1.5" back space, I already added a 1.5" spacers to my truck, and this makes the tires even with the fenders, if all I have to do is an additional .5 or 1" of spacing I am OK with that, but I am not sure if that is all it will take.
