Probably the end of my ‘17 Colorado
5.2K views 14 replies 13 participants last post by  daburket1
Had a guy pull right out in front of me yesterday and probably totaled the Colorado. I’ve only had it since last October but I loved this little truck. I am a little disappointed the airbags did not deploy.
If you walked away relatively unscathed, the airbags probably would've done more harm than good. Hard to say, but I don't think they should've gone off in that situation personally...
I will also take the time to say, don't worry, that'll buff out. ;) Glad you're okay.
Reactions: TheDill94 and Red06
What did you hit?
That looks like some major damage.
From what I have heard you got lucky the airbags didn't go off, people say that the airbags hurt more than the accident.
Well hopefully you are Okay
So sorry to hear about the accident
Yes, I would be willing to place money on it is Totaled
Glad you’re not hurt. Sorry about your truck…. Hopefully you will find one that you like even more. Maybe even a Canyon that same awesome Summit White! ;)
Reactions: Matcoman1
#12 ·
Airbags generally will not deploy on a corner impact. The sensors aren't located there. I'm sure there is an engineering reason, and given that despite the damage, you seem to be OK, their reasoning seems to be correct. The purpose of air bags is to slow down your body's deceleration rate, not to be a cushion as most people believe, and as the picture shows, the crumpling sheet metal and other parts performed that function - as they are designed to do. Sorry for your experience but glad you didn't suffer any injuries.
#14 ·
It used to be that an impact over 5,15 degrees off the center line will not blow the bags. Off center angles and the bag blowing could push the passengers into the doors, door glass, each other causing other injuries. If you has a front seat passenger I would have thought the passenger side curtian would deploy? To protect there head from hiting the door glass.
All to often replacing air bag and the associated parts will total a repairable vehicle.
FYI I have 40 years in body shops.
Glad you were not hurt.
Luck
