no rear blinkers
4K views 9 replies 6 participants last post by  Pockets
Hope you guys can help me out. I just was doing a routine check on all my lights and found that my rear blinkers do not work. My brake lights do work, however, if i hit the turn signals, no dice. if i hit the emergancy flashers, no dice.
I am NO good a diagnosing electrical problems.
BTW i have an 05 crew cab colorado.
Any suggestions as to where to go first?
Did you check the fuses? Have you done any mods that might affect them? And finally, have you pulled the bulbs to make sure they're good?
You can test the wiring by removing the bulbs, starting the engine, turning on a signal, and sticking a wet finger into the bulb's socket. If you get a intermittent shock, it's fine. If you get a continuous shock, you have a issue.
I just checked the fuse. All things look good under there. No problems. It's too dam cold and dark out to try the ol' wet finger trick. I'll save that for tomorrow when it's light out. :?
Oh, another question while i'm at it, if i don't have factory fog lights, why would i have one of the fuses for them. There should be two, according to the diagram, but for some reason, i have one of them. The big grey one. Not a big deal, just wondering. :)
