Would this level of coolant keep my heat from blowing hot in the mornings? The last few weeks my heat won't get warm in the morning. But right now in the afternoon 75 degrees out it's hot. 2016 z71
yep, that's why I said check for leaks. post #5Is nobody else worried he might have a cooling system / heater core problem? Coolant doesn't just dissappear and that is substantially low. If you haven't had recent work done that involved draining your cooing system, you are likely leaking it from someplace. This should really be checked by a pro. Any chance your hvac system smells off (fishlike)? Any hard to remove fogging on the windshield when you try to run the heat? These are normally signs of heater core leaks. After that you might want to get your whole system tested for leaks. This can be done with uv dye if a leak isn't obvious. I'd bet that if you fill it your problem will go away but return shortly after it releaks. Cooling is not something to take chances on.
Not near as easy as keeping the coolant at the proper level.Heater core leaking is normally recognized immediately by wet carpet and antifreeze smell inside the cabin. My experience with other vehicles has taught me that coolant has to be super low for heat to not work but maybe Colorado’s are different. I always go to the thermostat first. It’s an easy enough job, it’s cheap, and they usually go sooner or later anyway so it saves you overheating on the road later.
Interresting but what does this have to do with coolant leaks??Check the weeping hole on the water pump (maybe cover it with talcum powder or flour). I had this same issue with my Lexus. It leaked out enough to drop the coolant level (and my heater would stop working). I could never figure out where the leak was because it was evaporating and not dripping. Finally stole my wife's make-up mirror and spotted the leak.
