GM Bed Lights - Plug Identification
1 reading
3.9K views 7 replies 4 participants last post by  mschultz
I'd like to use the bed light harness to trip a relay for my load lights. Does anyone know which parts I need in order to make use of the factory plug located by the driver-side rear taillight?
Thanks in advance.
-Mike
394237
394234
394235
This was just answered in another thread, let’s see if I can find it.
Here you go
First off, I was wrong it is not made by Molex...it is actually a TE Conn which is why I couldn't find it in the Molex MX150 series. Thanks for the curve ball, GM.
Anyways, I took a look at mine and instead of the sealed plug cap it has the actual connector with a pigtail ready to go. This made it much easier for me to find all the parts you will need.
View attachment 394090 View attachment 394091
The main part number you need is the plug 1-1823608-5
1-1823608-5 | TE Connectivity
but since that is a GM part number the compatible parts are masked...
For referencing the hardware I would instead use part number 1-1718643-1
You'll need a couple female crimp terminals and wire seals for your wire leads:
Terminals: CAT-M4595-T273 MCON Tab and Receptacle Contacts
Wire Seals: 964972-1 AMP : 964972-1 Automotive Seals & Cavity Plugs | TE Connectivity
If you want to make it quick and easy, this eBay listing (no it is not the AATS connector lol) has the plug and terminals for $11:
You would just need to find the wire seals or dab some silicone into the cavity to keep moisture out.
