I have a 2005 Colorado with 105,000 miles on it, I've been noticing some start-up problems and now know its the fuel pressure. I bought a test kit and it read that my fuel pressure was only at 15 psi and the truck had only been sitting for about 10 hours. I turned the key to the on position to let the pump run for those few seconds that it does and the gauge shot up to 55 psi. But it immediately started dropping after the the pump stopped. It decreased pretty rapidly; about 5 psi every minute or so. What needs to replaced? I've already replaced the fuel filter, and fuel pressure regulator. Could the pressure be leaking from anywhere else? Personally I think its the check valve part of the fuel pump. Does the fuel pump need to be replaced. Any advice, help, and/or suggestions would be greatly appreciated.
