2017 Colorado
Question: I've been looking at doing a coolant flush because I will be replacing my thermostat, but actually came across a different repair video that involved the coolant in the block being drained, with some nasty buildup over time just sitting at the bottom of it where the coolant would drain out of the block... They literally took a screwdriver to push through the buildup to get it to drain out...
Anyone pulled the engine block coolant plugs on a 2017 or newer Colorado/Canyon when doing a flush that can confirm if there is a lot of buildup there? I haven't crawled under mine yet to see if I can even get to the plugs... if I can, figured it would make the flush even cleaner...
Thoughts? Also curious how many quarts of water would stay in the block (if not drained out) during flush?
