DIC Stuck on "Cleaning Exhaust Filter Continue Driving" After Delete
1 reading
23K views 33 replies 14 participants last post by  Jbomb001
#1 · (Edited)
Awesome info thank you! So theoretically, if you check your soot values and they read 0 before doing your delete you shouldn't have this issue? Can you manually force a regen with a scan tool?
Also, since you said all 5 temp sensors need to be fooled, does that mean you aren't running any temp sensors in your deleted exhaust to monitor egt's? Or are there others?
In theory, you can proceed if your soot is 0 already but you need to keep this small tidbit in mind... At one time during my problems, my soot was actually reading zero. The problem was that a regen had not completed once triggered so even though the soot was zero, the soot loading models did not reset, and the regen will still try every key cycle until completed
That's correct. All 5 sensors are removed and it don't really matter. While they do report temps, they don't react fast enough to be useful for anything tuning related. Also, they are too far down the pipe to be used to for tuning. If you want to monitor egt, pull up an obd scanner and look for egr temp sensor 1, that sensor is in the exhaust manifold. Again, while that one is located in the manifold, it is still the same sensor type that is in the exhaust... Not fast enough of reaction time... And no, scan tools that I know of cannot trigger service regen... Only gm or gm licensed scan tools can do that to my knowkedge
The sensors are not thermocouples, they are thermistors in a protective housing
If you want, find an adapter for the egr temp sensor in the exhaust manifold and install a true thermocouple there and remove the stock sensor. If you unplug the egr you will have not further use for the sensors
Sent from my Nexus 6 using Tapatalk
Nobody said anything about fooling the manifold temp sensor... The only sensors that need dummied are egt1-5, and all of those are in the exhaust... If you were referring to the egt1 sensor which is actually located in the downpipe near the bellhousing, that is the pre-cat sensor that let's the ecm know if it is safe to start dosing fuel via post injection to light off in the first cat to raise exhaust temps for the downstream scr that requires heat as well as ammonia to convert NOx to harmless gas and water vapor
#10 ·
This is still very much relevant... You can avoid this by ensuring you have done a regen recently and your soot level is less than 20% before you delete. If your ECM had already requested a regen, you may not know it in the early stages. It would be best to postpone your physical delete until after your next regen completes. Then do your delete within the next 100 miles... I'm speculating on the measurements but they should be good enough to get you where you need to be
Sent from my LG-H918 using Tapatalk
#11 ·
Nothing in the way delete tunes are done has changed, nothing has needed them to change... The base that we made almost a year ago is still current and no further advances in the software are needed. This my not apply to all people, this article fits the scope of a very small group of people. I was one of them.... And out of need, a solution will rise
