Compustar Cm 7200 with BLADE-AL wiring question
5.1K views 5 replies 2 participants last post by  Mrazpv2112
Has any installled a CM 7200 with the Blade bypass. 2005 Colly. My problem is with the blade wiring harness. Two questions Where is the diver side “door pin” “- polarity” located and what is the setup with the diode 1n4001 that is supposed to go to this wire? Do I need this?
393712
Discussion starter · #4 ·
Question about the Blade-AL bypass... I flashed it along with the Cm7200 all goes great when plugged into the computer (the LED is blue) When I plug it into the wiring harness the blade unit only shows a "Red colored LED". I installed the diodes and checked the voltage and polarity on the wires. I've researched and cant find any info on why its not working. Also I can hear the relays in the unit "clicking" during the learning phase.. However it always stays "Red". Again any thoughts would be helpful
Discussion starter · #5 ·
Update make sure not to forget the “learning “ setup . Once I did that it the LED turned blue. It had learned my vehicle. My problem now is the remote will lock and unlock but not start my truck. Is it because I didn’t install the hood pin? B/c I wasn’t sure what wire to attach it to. Any help anyone...anyone...Bueller.
Discussion starter · #6 ·
Colorado’s have Tachless starts.. make sure when updating the firmware via idatalink you choose Tachless. Once I changed the setting it started right up. Anyone have any thoughts on why the lights don’t flash when the remote is activated. I used diodes on the door and dome light.
