clean and clear headlights
4.2K views 3 replies 3 participants last post by  rwright
What do you use to keep your headlights clean and clear? Remove oxidation for example.
When you repair headlamps you are actually removing the UV coating. The headlight restoration kits come with a synthetic wax like product but wears off fast. Once you perform the repair you need to actually spray a UV coating on them and bake them under a UV light to cure or you can apply a product like Optimum Opti-Coat 2.0. Optimum should be releasing a lens coating in November at the SEMA show.
