Just like the days of Mini Vans. Mini Vans are going extinct as well.First, cars are pretty much dead, few people are buying. The wave of crossover SUVs has all but wiped out the car market. Go to Chevy's website and pull up the vehicle choices: They list SUVs, Trucks, EVs, Cars, Performance
The Corvette is an outlier, a performance vehicle. The Camaro is listed there, but I thought they had discontinued it.
In SUVs, I agree, it seems like the SUVs overlap so much in size, etc. I would think they could consolidate the group of Trax, Trailblazer, Equinox, Blazer and Traverse could be compressed down to maybe 3 vehicles, and then a new vehicle in between those crossovers and the Tahoe would be a good fit.
If you look at the SUVs that Chevy has, there is just over a $13K spread between the Trax and the Blazer starting MSRP (Traverse is slightly under the Blazer?) and then almost a $20K jump to the Tahoe MSRP. A $40K Body on Frame SUV based off the Colorado would fit nicely in that gap.
In my neck of the woods, probably SUVs (crossover-flavor) are the minivan of today, but there are a lot of 4 door Wrangler Unlimiteds being driven by the soccer moms of the affluent.Just like the days of Mini Vans. Mini Vans are going extinct as well.
I did, that's where I got the numbers.First, cars are pretty much dead, few people are buying. The wave of crossover SUVs has all but wiped out the car market. Go to Chevy's website and pull up the vehicle choices: They list SUVs, Trucks, EVs, Cars, Performance
Pretty much what I was thinking. Small, midsize and large. You could also throw in an economy hatch back and call it a crossover (what the Trax kinda is) and an offroad oriented SUV, possibly based on the Colorado (what this thread is about). What you don't need is a Trax and Trailblaser SUV or a Blazer and Traverse. You could even rename the Suburban the Tahoe XL or something, they really are the same thing other than length.The Corvette is an outlier, a performance vehicle. The Camaro is listed there, but I thought they had discontinued it.
You mean like GMC did with the Yukon? I think Cadillac did something similar with the Escalade.... You could even rename the Suburban the Tahoe XL or something, they really are the same thing other than length.
Exactly. Doesn't change what is really offered but it simplifies the lineup and makes for less confusion. Like when you could buy a coupe or liftback version of the same car, not a separate model (does anyone still do that?).You mean like GMC did with the Yukon? I think Cadillac did something similar with the Escalade.
The green one at the bottom is a friend of mines Blaze. It is very nice. He even rigged up a hoist to remove the top in the garage by himself.If GM came back out with this body style with updated gadgets and drive train, I'm afraid my Colorado would be but a memory:
GM changed the body style with the 73 model and while I loved mine, it was a real POS. The tops cracked in the rear along a seam due to the body flex. This wasn't limited to a few, literally every one of them cracked, even if you didn't go off-road, although off roading certainly exacerbated the problem. I had mine fixed 5 times. The last fix kind of worked, it that it limited the crack to a joint that at least didn't spread or leak. To "fix" the top issue, GM redesigned the truck making the the cab portion metal and permanent with just the back half removable. This change happened with the 75 model, IIRC.The green one at the bottom is a friend of mines Blaze. It is very nice. He even rigged up a hoist to remove the top in the garage by himself.
I first saw they were going to replace the Blazer with the Tahoe I thought that will never work. Well the Tahoe sales proved me wrong.
Some where along the way people started to chose 4 doors over 2 for ease of entry. Same today applies to the Wrangler.
GM needs a life style vehicle like the Jeep. A removable roof and doors. These models are the new pony cars as they can be modified but not touch the emissions. Women love the removable tops. It just is cool with the younger buyers. We sell Jeep parts today like Mustang parts in the 80’s.
I would love to have a 72 Blazer.
I never got to own one but I had three friends with them. I got to drive there’s and had wished to buy one one day.GM changed the body style with the 73 model and while I loved mine, it was a real POS. The tops cracked in the rear along a seam due to the body flex. This wasn't limited to a few, literally every one of them cracked, even if you didn't go off-road, although off roading certainly exacerbated the problem. I had mine fixed 5 times. The last fix kind of worked, it that it limited the crack to a joint that at least didn't spread or leak. To "fix" the top issue, GM redesigned the truck making the the cab portion metal and permanent with just the back half removable. This change happened with the 75 model, IIRC.
Then there was the sheet metal. GM bought the steel from Japan and it literally started rusting within a year. With poor drain designs that quickly clogged with leaves and debris, fenders were rusting through within 3 years, whether the truck was rustproofed or not. Within 5 years of introduction, you couldn't find a 73 model in the "salt belt" that wasn't a rust bucket.
Lastly was the under powered V8. The muscle car era was definitely over and the Blazer 350 had something like 165 hp rating, making it a real dog.
Still, the body lines were iconic, the short wheel base helped with weight distribution, the removable top made for great good weather driving and the tried and true straight front axle made for easy lifting and gear swaps. Plus the engine bay had plenty of room to hold any engine you wanted to drop in with ease. Increasing tire size was relatively easy and removing the rear seat (4 bolts) gave reasonable storage area.
Shots of mine:
