Hey Guys,
So we were lucky enough to have a local customer stop by the other day with his ZR2.
After taking some measurements and playing around with CAD, the ZR2 has a different frame, arms and spindles.
But, we will have a Prerunner kit for it!
Here is a break down on the kit...
- 1.5" wider for more stability
- 11" wheel travel
- Same custom King 2.5" coilover as the ones we use now for the Colorado
- Can run a bypass shock
- You will now be able to adjust the ride height.
- Our arms are more heavy duty and more durable
- Will not work with stock shock
- Will lose sway bar
- Need Method wheels
The only 2 things we need to check out are the axles to make sure the spline count is the same as the standard Colorado and the tie rods,
That is very easy for us to do.
The same customer will be coming in and dropping off his truck for us to do the build
I will keep everyone updated with pictures.
If anyone else is interested, please email me at JT@Bajakits.com
We can definitely work out a deal for you.
Thanks
JT
- 11" wheel travel
Thanks
JT
