I'm still doing some planning in my head for the new Colorado I've ordered. Been reading a lot of posts and asking questions. I'm leaning towards the Peak Suspension adjusted to 3" lift, but trying decide if I'll get one of their packages with the DirtKing UCA, or if I should buy the BajaKits one separately. Also researching other options.
There's a review in here on the Freedom UCAs which might be an option: Freedom Off-Road Upper Control Arms (UCAs)
There's also the Pro-Comp UCA, which sounds like is much lower quality than the others, so probably tossing that out. Any others I should consider?
I think I'm really just down to the BajaKits vs. DirtKings. I like to save money like anybody else, but I also like to get things done right the first time, so I don't know if saving $200-300 on the cheaper ones is worth it in this case. So, just looking for some opinions on the comparisons. I know they both have boxed arms and uniballs. The BajaKits advertises 8.25" of added travel, but I don't see that spec listed for the DirtKings. Any opinions or advantages/disadvantages you guys can share with me? I'll also being doing the diff drop, and am trying to figure out sway bar and/or tie rod changes as well.
BTW, planning on 1.5" lift Deaver springs in back to get to level. I can live with touch of rake, but I certainly don't want the front higher than the back.
