I have a 2020 Colorado 4WD Z71 Crew Cab Short Box with the 3.6L V6. The air conditioning seems to always be on even though the A/C and Recirc indicator lights are both off. The A/C compressor clutch is always engaged during these times. The only way I have found to stop this condition is by turning the climate control off. I have the thermostat set on 68° and when I raise that temperature to 80°, the air will be warmer but, the compressor clutch continues to spin. Any fans out there have any suggestions or explanations? Thank you in advance.
