Short vs Long Wheelbase Towing
5.5K views 13 replies 10 participants last post by  DieselDrax
My 2018 Duramax is a short box/short wheelbase model. We have towed our 19' 4500 lb camper with pretty good results. However, I am thinking the long bed/long wheelbase would be even better. My question for those who know is simply.....is there a noticeable difference in towing stability when comparing the longer wheelbase vs the short? Common knowledge tells me that yes, the longer the wheelbase the better the tow. I'm willing to hear what folks have experienced in the real world.
BTW, I'm getting 14 mpg towing this camper at 68-70 mph. I'm pretty excited about that.
Yes you need a new truck!! :)
Tell your wife it’s decided and head to the lot. JK- is the towing capacity different on the long bed?
My CCLB tows great, however I have no experience with the CCSB to be able to compare. Not sure if anyone here has towed with both, hopefully if someone has they'll see this thread and speak up.
Sent from my SM-G986U using Tapatalk
owns 2017 GMC Canyon Denali
Come on fellahs, Chevy puts out nifty spec sheets for these trucks that are very easy to find. Towing capacity is the same between CCSB and CCLB. Only difference is about 50# gained from the extra foot of truck.
@29er would any suspension mods resolve issues you are trying to overcome? Perhaps a rear swaybar, better leaf springs, better shocks, more tire pressure, etc? Or maybe better weight distribution in the trailer? Too much or too little tongue weight? Sure a longer tow truck will be more stable, but what is the root cause of the issue?
Good point. I'm sure these things could be looked into to improve the stability of my tow. But I'm also wanting the extra bed space to allow more room for hauling my mountain bikes when I'm not towing, so that is also a reason. My bad for not mentioning that.
I am surprised at your 14 mpg on the Duramax, that’s what I get on my V6 towing the same size trailer.
Reactions: Firehk
#9 · (Edited)
Just a theory, but I would imagine a longer wheelbase would provide a greater mechanical advantage. The rear axle being the fulcrum, and most of the truck weight extending further in front of that fulcrum == more leverage. But that wouldn’t necessarily apply if you used a weight distributing hitch; all four tires should receive equal weight. One thing a longer wheelbase will absolutely do...the longer wheelbase will give the towing vehicle a larger footprint on the pavement. That larger footprint makes a big difference in how it handles stability in crosswinds. It provides a greater mechanical advantage on the horizontal plane (the (vertical) center of the rear axle being the pivot point). A longer wheelbase will leave the driver less fatigued after a long day of driving.
#10 ·
All else being equal, a longer WB will always be a little more stabile when towing. It also provides a slightly smoother ride.
Last week I towed a car on a tow dolly from upstate NY to the coast of NC. Running around 70mph, I averaged 20mpg.
Then I towed a 5x8' U-haul trailer from NC to CO. It wasn't heavy, but it's a big square box. I averaged about 20mpg until OK. Then I ran in to a heavy wind off the port bow, and mileage dropped to about 14.
#11 ·
Some years ago I towed with a Chevrolet Tahoe (4000 lb trailer, no weight distribution, and 500 lb tongue weight) one time. It was terrible as far as sway from side winds, and always convinced it was because of the relatively short WB. My current setup with weight distribution and ~5000 lb trailer is rock solid. All that said longer wheelbase should be better on paper.
#13 ·
Wouldn't the short wheelbase help distribute the tongue load to all four wheels better than the long wheelbase?
#14 ·
Nope, but it helps take more weight off the front axle if you're not using a WDH! If you're using a WDH then it's all about WDH adjustment to get the weight properly distributed.
