Where the vacuum line plugs into the big black box before the throttle body I have no vacuum.
At first I thought it was odd because typically at wide open throttle the lower vacuum should let the regulator close and add about an extra 5-10 PSI of fuel pressure to the tips of the injectors.
However you don't have vacuum before the throttle body so why is it set up this way? I was trying to figure out why I have a shudder at idle that gets annoying and went with a slight lean miss idea and went after a vacuum leak.
I smoked the whole intake and found nothing and started it and unplugged the line to the fuel pressure regulator and was expecting to hear a hiss and the RPMs to jump a hair.
Nothing, Found this rather odd.
So if someone wants to pull off their line to the fuel pressure regulator and see if they have vacuum. It seems it should but because it is before the throttle body it shouldn't and it just doesn't make any sense.
Thanks in advance guys!
