Before anyone can answer that we need to know what sort of daily driving routing you would be doing with it. Modern diesels don't like it when most drives are short as it will lead to emissions issues. If the truck will be driven regularly for at least 30 minutes then that will keep it happy, but if it's going to mostly be short, low-speed trips into town where you're not driving for more than 10 minutes at a time then a diesel isn't going to do you any favors.
That aside, with 102k I'd say most issues likely would've popped up by now so if the repair history is short/minimal then that's good news. It would also be good to know if the previous owners used fuel additive or not. Some owners have had pistons fracture with no proven root cause, this also happens on the big 6.6 Duramax. My current theory is this happens if the truck runs low-quality (low cetane) fuel often, the "diesel rattle" folks seem to like is actually a bad thing on common rail diesels most of the time as that rattle is the ignited fuel hammering the pistons. Running a good cetane-boosting diesel additive every tank helps avoid the affect of low-cetane fuel and the engine is much happier. It's quieter and has better throttle response when the cetane is bumped up a bit because US diesel is pretty awful in that regard due to the US setting a minimum cetane number that's lower than it should be.
