Which Would You Choose?
586 views 9 replies 7 participants last post by  AZDieselGuy
Hello Everyone! This is my first post on this forum so apologies if this feels like an old topic/discussion. I am in the market for a new (to me) vehicle and I am strongly considering a Colorado or Canyon. This truck will live on the street 95%+ of the time but I'd like to get into some mild off-roading/trail riding with it as well so want to have some capability there too.
In lieu of a V8, I have always preferred the sound, feel, and driving characteristics of a V6 over any type of 4 cylinder. But I have to admit, the 430lb-ft torque rating of the new TurboMax engine is intriguing. Admittedly, I will do very little towing and likely never come close to pushing the limits on towing capacity so it may not make much difference.
So far I've read that the 3.6L V6 needs revs and, looking at specs, seems underpowered from a torque standpoint for "truck stuff". However, those shortcomings appear to be easily conquered with a Mallet supercharger (or similar); would also make it much more fun/lively for street use. So the question is: All else being equal, would you rather have a 2nd gen V6 with the Mallet supercharger or the 3rd gen TurboMax engine. Torque numbers would be about the same, but horsepower would greatly favor the 2nd gen. For those that maybe have experience with both, how do they feel on the street, off road, and when towing?
#2 · (Edited)
In normal driving, i did not notice much of any difference between the 2 stock motors
I have/had 33's on both my 17 and 24 trucks. pulling the 3,000lb boat, not much difference with either.
both have the same transmission in which the last 2 gears 7 & 8 are both over drives, so they both down shift on hills when you have the cruise on.
running 70mph down the highway engine runs at the same RPM. same gearing
you may see the difference between the 2 if really loaded down, pulling max trailer weight.
or putting on 50 to 65lb tires like some do
both trucks are capable for trail running in stock form.
Reactions: quattljl
I am not actually sure if there are many folks on here with both a supercharged 6cyl and Turbomax experience.
Minus the sound, the Turbomax is a lot of fun. The low end power is a riot and it can definitely boogie from one grocery store to the next.
That said, the uniqueness of a supercharged 3.6 almost sounds more enticing. Definitely going to sound better and that extra HP might make for more fun interstate merges than the Turbomax could as its top end speed is a little underwhelming.
I definitely want to drive the TurboMax to see how I like it. I'm leaning towards the 23+ as I do like the upgraded styling, tech, and interior. My strong preference against 4 cylinders and turbo whistle is what's turning me away. Having previously owned a gen 2 CTS-V, I'm definitely partial to the feel of a supercharger and admittedly I do love the whine when you get on it.
I may be a little biased but I think the 2.8L Duramax takes the cake. But that opinion comes from experience. I'm glad you acknowledged the v6 needs revs to make torque because that was my main gripe about test driving one as well as driving other cars with the same motor. I'll admit the duramax sounds like a muffled tractor and a supercharged V6 will probably be more exciting from an audio standpoint but it makes up for it with the gobs of torque down low and unbeatable fuel mileage. I chose to stay away from the turbomax motor when shopping for a new truck just given that the platform hasn't had a lot of time to prove itself. (and from what I've seen on this forum they're showing to be pretty unreliable.) Though when I test drove the high output variant in the new ZR2 it was a fun little motor, it's just not what I want. They tried to make a gas engine do all the things their diesel already did years ago.
I know it's not one of the options you mentioned but from what it sounds like you want from a drivetrain in a truck I think it's worth considering. Either way I hope you enjoy your next truck!
#9 ·
I had a '19 V-6 Bison for a couple of years, and I bought a '24 Bison back in April. I did a fair amount of off roading and long distance road trips with my 2nd Gen Bison and I never thought it was under powered and I never had any issues with it. In almost every way though, my '24 Bison is a better truck for my use case.
There are really only 2 things I'd change about my '24 Bison. One is the turbo lag. I've never been a big fan of turbo motors, and from idle to ~3k RPM it's gutless. But, once the turbo spools up, it'll kick you in the ass. It takes a bit under 2 seconds to hit 3k from idle, which doesn't sound like a long time, but when you're in traffic that comes to a sudden halt and there's a tractor trailer with smoke pouring off its locked up brakes rapidly getting larger in your rear view mirror and you need to get out of the way quick... That 2 seconds is an eternity.
That said, when I'm in playing in the dirt in Baja mode and "Performance Shifting" engages, the computer holds onto gears longer to keep the RPM's up and the power delivery is great. It's really pronounced in 4-lo and off road mode; the turbo spools up quick, the RPM's stay high, and the diesel like torque is great.
The other thing I'd change is the infotainment system, I think the 2nd gen's is better. In all the reviews I watched and read before I bought my '24 Bison, everyone was very careful to talk about the driving and performance improvements over the 2nd Gen trucks and if the infotainment was talked about, it was to point out how there is no physical light switch anymore. If you want to control the lights, you have to do it via the touch screen. All in all, the 3rd Gen infotainment is clunky and could have used a bit more thought. I've said for a long time that printer companies (HP & the like) shouldn't write software, because they suck at it. It seems like car companies shouldn't write software either, because they also suck at it.
TL;DR, for a street truck, I'd probably go with a blown V-6 2nd Gen. For an offroad truck, the suspension improvments and (surprisingly) the turbomax in the 3rd Gen are the winner.
