Installed my tonneau this weekend.
Ordered Friday night before Labor Day, after close of business, so it was not accepted till last Tuesday. Arrived late Friday afternoon. Box was 18" longer than bed of my truck, marked for short bed, but I was afraid they shipped the wrong cover. Opened up and there was 18" of dead space in box.
Here is the link:
https://www.realtruck.com/xr-tonneau-cover/
Price $247.99, free shipping.
Install went pretty well. Written instructions were good, but the pictures were the pits. Looked like someone scanned some old Polaroids. Took me about an hour by myself, partially because I was trying to reconcile pics with the written instructions. Also, instructions were in 3 parts:
Part A: Generic instructions.
Part B: Special instructions for the bed rail clamps for the Twins
Part c: Special Instructions for the seal up at the cab area of bed.
Nothing in Part A told you when to go to Part B or C, so I read the instructions a couple of times to make sure I was doing the right sequence. The clamps, especially the one closest to the tailgate, took a bit to understand, the Polaroids were awful, but they had drawn out a schematic and once I ignored the pictures and just used the drawing it went fine. Biggest problem I had was either the truck bed rails or the covers rails are not straight. The cover rails are supposed to line up along the truck bed rails. If I lined up the front & back of the cover rail, then in the center of the length, the cover bed rail was almost an 1/8" lower than the truck bed rails. I messed with it a bit, and this morning when I was looking at it again, I decided I might make a small adjustment before we see our first rain. Note: an extra set of hands on this would work better than the spring clamps I used to support the cover rail while I was mounting the rail clamps.
The bed rail clamps at the tailgate utilize the stake pocket/hand hold. Doesn't block access to the pocket itself, but it does use up the mounting hole in those stake pockets. There is an alternate method to free up the pockets, but I was comfortable that I would not have any issues as I just want the pockets for a handhold.
The picture of how to mount the tension adjustments for the cover were difficult to understand. Once I figured it out, the mounting of the cover itself went extremely quick. Probably 5 minutes.
I haven't had a chance to check for leaks yet. Supposed to get some rain at end of week, so by end of weekend, should know. Hopefully I can make a small adjustment before then to the rails. I have some concern about the rear of the cover over the top of the tailgate - doesn't seem like that is a great seal.
There is a slight flutter. I reduced this some by increasing the tension adjustment. Finally, when I first installed the cover, I just went down each side and made sure the velcro was in contact with the cover rail. When I pulled one side back up and pulled some tension on the cover before pressing the velcro down, this seemed to help. While there is a tension adjustment front to back on the cover, nothing for side to side.
Few positives I noticed:
1. I thought the person at Realtrucks I chatted with said there was only one strap to secure the cover when it is rolled up - but there are two.
2. Opens from one side, but there is a secondary slide that can secure the passenger side for more security. Based on my drive this morning, doesn't seem necessary.
3. There is some flutter, but I am not sure a soft cover could be built to remove all of the flutter on a 4' wide x 5' long soft cover. Totally acceptable.
4. Extremely light - shipping weight was just over 26 pounds, so I would guess that installed it might have added 25 pounds to truck.
One issue I noticed that I do not think anyone has mentioned was the impact of the cover rails. The bed rails on our trucks are tall. Reaching from the side into our trucks is difficult, even for me at 6' 1". The cover bed rails extend into the truck 2" - 3" on each side. This requires you to reach that much further into the bed to get an item, it also hides the tie down hooks under the cover rail a bit, making them harder to reach. I don't think this is specific to this cover, any cover rail is going to have some impact to the "reach" into the truck bed.
I haven't added any seals to the side of the tailgate yet, want to see how it performs before I add that, but I expect I will find I need to do so.
Some pics:
