Transmission Shifter Question-L
1 reading
1.9K views 11 replies 6 participants last post by  BillBoost37
I finally shifted transmission into L while stopped in a big parking lot. As I left, it stayed in 1st gear. The little +/- buttons on the shifter had no affect.
What am I doing wrong?
Nothing, sounds like it is not working,
when it works correctly, if you put it in L when stopped it is in first gear and will stay there until you press the + then it will shift up to how many times you press the +, will shift down on its own as needed but will not go above what you press and it will show on the DIC
so, did the DIC change at all while you were pushing the + button? it will change no matter if you are moving or not
if not, it need to go to the dealer.
some people who tow or crawling or muddding will leave it at a certain number so it does not shift up to a higher gear but still shifts down on it's own
You aren't the only one, there is a thread or two about the issue
One thing you might try is shifting to L after you are moving along at a decent speed and seeing if the buttons still do nothing. Based on the manual shifting to L will reduce gear by 1 typically if you are moving. But you should then be able to limit them up/down using the buttons. Might be a way to test if your buttons are not working at all.
#8 ·
I beleive they call that avoidence submission... Reminds me of the guy that never uses the parking brake and 10 years later needs to use it and the cable snaps when he needed it most because it rusted and had dry rot from never using it...
#10 ·
I drive in the mountains fairly often, and drop it in L while rolling to slow down on downhills, and it's never had a problem. It WILL prevent you from dropping into too low of a gear, and flashes a warning on the dash, so that's cool. Sounds like you have an issue. As mentioned, try dropping into L while you're rolling, and see if that doesn't reset it? It will always select the same or a similar gear to what you were in while in D. I WISH there was a small gear indicator (D1-D8?) while you were in D though like it shows in L, that would be cool.
Best of luck!
#12 ·
Funny enough the other day leaving the store I must have thought I was in the 4Runner with gated shifter and slapped the truck shifter straight back into L. Tested out the buttons once I realized what I did. They work correctly on my truck.
I'm almost afraid to say anything about how great the truck is and how everything works well. Don't want to jinx it.
