I've found there are many brands or options when searching for TPMS Sensors for the 3rd gen. For those of you who bought new wheels and installed sensors - which ones did you go with , did you have any issues. You can see there are no less than 6 Part # for OE TPMS Sensors - if you have clarification on new #'s or old , etc share and i'll update this thread. Maybe we can turn this into a Sticky if it gets helpful.
I'd love if someone who has done the relearn process could comment if it's built in or you need an Autel type relearning machine. If you want to post the process for relearning for people that would be good info for the thread too.
GMC OEM Schrader TPMS Sensor 13533166 433MHz
GMC Schrader 33500 EZ Sensor TPMS Sensor 13533166 13542523 433MHz
GMC TSS1 TPMS Sensor 13533166 13542523 433MHz
GMC Huf IntelliSens TPMS Sensor 13533166 433MHz
GM Genuine Parts Tire Pressure Indicator Sensor
GM Part # 13556202
ACDelco Part # 13556202
(Old part numbers.... 84991144 and 84977020)
with Nut Part # - 19383801 19383802
GM Part # 13556202
