Tie down anchors
8.7K views 18 replies 12 participants last post by  HED
I have these Bull Ring Tie Down Anchors in my truck bed and they work really well for me. My only regret is getting 6 of them instead of 9. If you want more tiedowns on the bottom, I recommend L Tracks or the DECKD system with the L Tracks (Pictured)
414713
Install is really straight forward. I used the pick to pull the plastic covers out, nothing you couldn't do by hand or with a flat head. I threadlocker everything by default at his point haha.
414714
Reactions: Firehk and Hunter62
No rattle on mine. Snug as a bug.
I’ve always thought these would be perfect in a p/u. Indispensable in my days with various moving van lines. View attachment 414779
Why not just use L Track ? Then you can use whatever cargo strap you want, plus the 3/8" bolts, and tons of other stuff designed for it.
Reactions: HED
[emoji1369]this…
I’m going to be installing some L tracks into the gaps in the bed floor. They should be pretty dang close to flush plus you can pick up some rubber “covers” on Amazon that go over the tracks if you don’t want them exposed/need to protect your cargo.
My intended use to for a sliding tray for my Orca cooler that will be fully removable for when I need full use of the bed for hauling cargo.
Want to do all the work for me and see if you can mount some on the side between ribs too ? lol. It's on my list of things to look into. I have the bullrings which work great, so it's very low on the list.
