Seat Heater control bezel, 2019 Colorado
3K views 6 replies 5 participants last post by  Piggity
Does anyone know how to remove the bezel that holds the heated seats buttons? The bezel I’m referring to is below the info center, above the center console. Do I need to remove the console to acesss screws, or does the bezel just pull out. I’m afraid of breaking something. I want to hook up the seat heaters in the new z71 seats in installed but have no idea if the wires are present until I can get this bezel off...then I can order the bezel and switch’s.
Thank You!
Should just pull straight out. Get a trim tool in there and it should pop out.
Disclaimer: the seat heater buttons, like all the buttons/switches are controlled by the BCM. You may get to the point where it just doesn't work because it is not programmed to activate those switches, and a trip to the dealer will be required.
Thanks a bunch!
In your experience do you think the dealer will give me a problem flashing the BCM? I’ve read a couple horror stories.
I do hope the wires for the buttons are in the dash. Looked them up and what I found was one was like $11, the other $170 for some reason!
Thanks again
