Porting The Truck Bed For Subs
7.7K views 16 replies 11 participants last post by  turbizzy
This is what we used to make a passage from the bed of the truck to the inside. Cut out the sheet metal in a rear window shape in the front of the bed and then cut out the back of the cab the same size. Then you use the camper boot seal to connect and make a water tight pass through. You only cut out enough metal to make room for the ports and wiring. Just make sure to make the corners round so that the boot seals properly. This is the same material they use to connect the front window of the camper shell to the rear window in the truck.
http://www.mediatunes.com/papeenterprises/index.html
http://www.trucknvans.com/CRL_Slider_to ... 5381rl.htm
