So installed the conversion kit today with instructions supplied and must say it was very easy!
But one question, I have a feeling something is wrong but i'm not quite sure so just seeing if someone could clarify this.
I realize that with the kit, once i switch on my brights, my low beams and fogs will stay on. Question is though, when i'm running just my low beams, shouldnt i be able to still turn off my fog lights? Right now they stay on 24/7 unless my DRL are on. I flip the switch inside and the light goes out, but the fogs stay on, is this normal?
I did test, and all six lights stay on when flashing brights, but I would think I should be able to turn off fogs, and if i use lows, and flash brights, then only 4 lights would be on, not 6. Right? What did i do wrong?
These the the instructions i used and i guess the only point i got big confused was on the fog lights, it say to connect to the "positive" wire. Well i had a black and purple wire, so figured the purple one was positive. Was i right?
