Manual Regen and RPO FPF Code
9.7K views 5 replies 3 participants last post by  DieselDrax
#1 · (Edited)
Has anyone looked into the FPF RPO code - manual regen option for fleet/commercial vehicles. Wondering if there is anyway to retrofit this into our trucks so that we can initiate a regen from our DIC's.
Alternatively, is there a sequence we can enter (like the ones for oil life reset in older truck or the Transport Mode 404NotFound discovered) to initial the regen ourselves. I suppose one can do this through a tuner (which I don't have) or Torque Pro/Biscan for GM, but I wanted to know if we could initiate this ourselves without any special hardware.
Btw, if anyone is wondering what I'm talking about, its listed in the Diesel Duramax Owners Manual Supplement under "Manual Regeneration of Diesel Particulate Filter"
..interested as well..
It seems like everytime I go on a long drives (4-5 hours each way) I end up at 98% soot about the time I pull into my driveway, then have to smell the regen every time I get out of the truck for the next few trips of city driving. It would be nice to start it manually during the long drive if I know I will be making shorter trips during expected regen
That should never happen on a long drive, towing or not. The manual regen would be for fleet vehicles that spend a lot of time idling and/or doing city driving and need a regen to complete without driving. Unless you're talking about low-speed travel off the beaten path, but even that shouldn't be a problem. It's short drives and repeatedly interrupting the automatic regen process that causes problems where a manual/forced regen can be beneficial.
If you have a "keep driving" message on a long drive while towing then you've got a serious problem going on that a manual regen won't fix. You're more likely to encounter a DEF quality poor or service DEF system warning and that is something a manual regen won't help since it's for the DEF/SCR portion of the system and not the DPF/regen.
