Can someone tell me how many amp fuse do I need to install on the Power lead of my amp? Does it also depend on the wattage of my amp? If it does then my AMP is a 400 watt amp.
You are the ohm's law master superh and I concur use a 40 amp fuse.SuperH said:You don't want to go too high on the amperage of the fuse because then it may not blow soon enough, and potential damage to your equipment and/or vehicle could occur.
Use this equation: P=I*E, where P=power (400W), I=current (unknown), and E=voltage (12V). Solve for current. Take P/E (400W/12V) = I = 33.3A. You'll want a 40A fuse optimally in that configuration, possibly a 50A if your amp overdrives. Most likely, your amp has 40A worth of fuses on it already. The more overrated the amperage on a fuse, the longer it will take to blow. When a short occurs, the current doesn't instantaneously reach infinity. Integrated circuits require nanoseconds to switch between one another. If that surge of current reaches through and blasts a gate that cannot handle it, or any electrical component, then it may blow that IC or component. Nanoseconds of difference is what you'd see in fuse reaction times when one blows. Nanoseconds is all it takes to potentially do damage, whereas none may have been done before.
Now, using some equations I know, if you're using a copper wire, 10AWG will drop ~16% of its voltage at the end of a 20' length, based on 40A maximum current. 8AWG will drop ~10%, which is a grade of wire commonly used up to ~600W (and it will work). 4AWG, however, will only drop ~4% of all voltage, which is optimal.
200A fuse? I hope your amplifier had protections for power surges up to 200A, like a fuse onboard (like most have)!GlennH said:i ran a 200a Blade fuse on 2ga to my JBL BP1200.1 off my stock Ford Focus. very sick setup i had. 1x12" Adire Brahma MKII sub. WOW, was it loud. cant wait to hear it in a truck soon.![]()
