1 - 12 of 12 Posts
stixman6
· Registered
2023 Colorado ZR2
Discussion starter · #1 · (Edited)
Happy with the EGR in-channel vent visors; easy install, look good. Have used AVS in the past but I went with EGR because I wanted them in matte black and only saw them in smoke for AVS. Also was able to pop off the EGR logo for a clean look.
Looks Good
In Channel is the only way to go
Reactions: krellheat
Discussion starter · #8 ·
Haven't noticed any noise at all with local driving but I haven't had the need to take the truck on the highway yet since I put them in to check at higher speeds. Wil report back when I do.
Reactions: Spuds_Mackenzie
Looks good. How much extra wind noise did it add, if any?
If you are Wind Noise Sensitive
The people who are not Wind Noise Sensitive most likely will not notice the same sounds
I have ordered these and installed the rears visors (easier) then went to do the fronts. My front visors do not have any double tape. Is it missing?
Discussion starter · #11 ·
Only the rears had the double-sided tape. You need to bend the fronts slightly to get them in place and they're snug enough being captive within the channel to ever move; the rears need the tape because the fit within the channel is not as firm.
1 - 12 of 12 Posts
