Hey all,
I was wondering if any of you are seeing this same weird behavior that I am. I've only had to fill the engine with fuel 3 times now. (Only 1250 miles on the truck so far).
The first time there was excessive urea crystal buildup around the DEF Cap. I washed the area with water and wiped the area clean. The second time no crystal build up. Just tonight, went to fill the fuel tank and opened the fuel door and there is some crystal buildup.
I cannot fathom how this is happening. The tube that the DEF would flow down doesn't appear to have excess DEF there. The cap is tight. I took it off to double check and then turned it until it clicked.
I just want to be sure that there's nothing else wrong. I haven't noticed any wet spots where I normally park in the garage and at work, no white crystal build up on the ground.
Thoughts?
Thoughts?
