I just replace my Wifes Blower motor Resister. Let me just say it is very easy to do. Anyone that can read this can do it.
Under the dash on the passenger side you will see the back of the blower motor. Just to the left of it is the blower motor Resister. You will see the back of the resister. It has a flat plug on it. There are two 5.5mm bolts that hold it in. Pull the 2 bolts and it will come right out. Unplug the old resister. Plug the new one in and slide it back into place. Put the 2 5.5mm Bolts back in. Done!!!
Test to make sure everything is working.
Hope this helps some of you out.
