Back seat Delete
388 views 6 replies 3 participants last post by  Dash Riprock
I've found numerous threads for different ideas for back seat delete so I'm considering options found.
But, my question is... how to get rid of the wire loop thing on top? (see pic below)
Can this be removed or just bent over with some wire ties? I'd rather not leave it there since it looks goofy and isn't serving any purpose I'll be needing it for.
Hoooogan is correct the just bolts (2 each side ) to the body behind the seat back rest. If you can call them a rest, LOL.
The backs just side up to remove.
I make use of mine it holds my cb antenna and hats with a carabiner. I also replaced the back cushion with the OEM filler part from the Work Truck model. I don't now if they are still available. The part # is somewhere around here.
Luck
Reactions: HED
The bolts are behind the back rest, not the head rests. to remove the mounting plate remove the head rest, remove the back rest pad, remove from the plate the 2 head rest guide bushings by squeezing the tab that hang through the mount plate , remove the THREE bolts.
Maybe you need to look at a parts diagram to see how it all fits.
Maybe you need to visit a autobody shop for so help. Body shops are typically cheaper than mechanics.
Best of luck
No, won't be needing to do that.
Like anyone with experience working on vehicles I can study what I've not done before and get er done just fine. If others can do, I can too...No problemo.
If all else fails, I'll get out the trusty cuttin torch by gAwD and take care of bidness!
