Batteries are fine till they aren't, and what I know of typical AGMs, low charging will drastically shorten the lifespan. 12.7 (or higher) is the normal full charge for AGMs. Has anyone read that our battery is a different design?
I'm toying with the idea of using a maintainer when parked to hedge my bets. Any downside this?
Let’s clarify real quick, in case people aren’t paying attention to the sub forum, as diesel and gas have different OEM batteries.
I have diesel so yes i know mine are AGM
OEM diesel battery is AGM
OEM gas battery is ???
So here’s the thing with that, in the OEM charge cycle. It will only go as high as GM will allow it.
Take for instance I have 2 OEM batteries in my truck. The under hood one and a “house” one in the bed.
The under hood is 100% the way GM wants it. My alt. output is 100% inline with spec. When running if I test the terminals with a voltmeter I believe (going off memory) it tests at 13.2V which would be full but a bit later testing with the engine off it reads 12.5V.
Since my battery doesn’t drain and operates/charges normally, to me that means the OEM setup is designed not to charge beyond 12.5V and is just floating at a higher voltage while running.
I’ve come to that conclusion because my house battery is connected to a solar charge controller that is tapped into the OEM 7 way trailer harness for + and - charging. With the charge controller deciding how to charge the same battery it will charge to 13.2V and float at about 14V. Off charge it has maintained about 12.7V for weeks now disconnected.
I don’t think adding the maintainer is going to do much for you because the truck will just not top it off for a while once you start the truck and then the maintainer will have to catch it back up to what it thinks it should be when you plug it in. Essentially costing you money to charge your truck off your house every time you connect it and then the truck will just think it ok to drain a bit before it cares to do anything.
Can the battery hold a bit more than where GM is allowing it maintain? Apparently.
Is it worth the expense to pay to charge it up a bit more at home simply because you can? IMO no, there’s nothing showing that the OEM charge level is hurting anything.
