I've been looking for a way to upgrade the output of my stock projectors and high beams. I came across an easy mod where you use a 9011 HIR bulb in place of the stock 9005 high beams.
The 9011 HIR puts out just over 2500 lumens. It's much brighter and whiter light than the stock 9005.
Best of all, I didn't have to trim the locking tabs on the bulb. These fit the Canyon housing perfectly!
As for the H11 low beam, you basically do the same thing as above but you swap it for an H9 bulb, which puts out considerably more lumens than the stock H11. However, you do have to trim the base and the locking tabs on the H9 bulb. Here's some pics I found online... Picture says for fog light housing, but it's the same mod for our headlight housing.
These two mods keep the same stock beam pattern, but both are much brighter and whiter light.
