Hello All,
I have done some reading on the Coloradofans website, however if anyone with more direct information could respond that would be great.
2010 Chevy Colorado I4:
-Runs great in winter or when temps cooler out.
-Once outside temps reach say 60 Fahrenheit or greater engine runs rough.
-At start up the tach bounces quite a bit before settling.
-Upon acceleration the truck misses and bogs.
-Once theres air flow into the engine compartment truck runs fairly good.
-On hot day after driving, then restarting a few minutes later the truck nearly wont start.
-Cleaned the Mass air flow sensor, replaced with aftermarket, then factory GM Mass air flow sensor.
-New plugs and wires
-Can't recall but I believe my mechanic cleaned the throttle body
-Put in a mechanic recommended fuel treatment.
-Wiggled the pigtail on the Mass air flow sensor no change.
Truck is still running bad.
Any info would be greatly appreciated.
Another mechanic with more knowledge mentioned maybe the timing is off? However that is an in depth pain of a job it sounds like?
Thanks, Chris
Thanks, Chris
