2.7L L3B Turbo - plastic oil pan
2 reading
38K views 73 replies 31 participants last post by  TOK
Has anyone done an oil change with a metal pan? I’m looking for the crush washer that goes along with it. I contacted a parts department and even for the metal one it gives them the rubber o ring even for the metal pan. The metal and plastic pans are calling for the same rubber o ring which doesn’t sound right to me.
Also GM uses the same part number interchangeably, so 12732388 brings up the plastic pan even though it’s the part number from the picture with the metal pan.
my comment still stands bc OP said "I contacted a parts department and even for the metal one it gives them the rubber o ring even for the metal pan. The metal and plastic pans are calling for the same rubber o ring which doesn’t sound right to me "
you say different o rings. gm says same one.
I believe drax is right. I’ll post an update when I do my oil change in a few weeks.
