OK, let's see how prevalent this might be.
I would suggest getting it in to your dealer as soon as you can so they can properly diagnose the issue and do the work under warranty. The hard shift from 1-2 and 2-1 is extra wear on your transmission, drive line, rear differential, etc. Not a good thing and will just shorten the life of those parts.2017 cc z71, 12,783 miles, built in May 17, stock. Mine stays in too high of a gear when coming out of turns or if you don't mash the pedal when wanting to come out of a low speed cruise. It has a loud vibration that sounds like a dust shield rattling coming from the passenger side floorboard/tunnel. It also sometimes hesitates to find the gear between 1st and 2nd, revs high then slams into the right gear. I've learned to drive the truck to prevent it from happening and it's manageable when it does happen. Thanks to post like these I've come to accept this is just a characteristic of the truck and know it can be fixed with a fluid flush and change if It starts getting on my nerves too much but for now it's ok.
Yeah, this.‘18 2400 miles.
Not so much of a shutter, more of a clunk when releasing the brake and touching the pedal to accelerate.
Similar issue when braking to nearly a full stop as the trans comes down into 1st gear.
Both issues are intermittent and temps haven’t seemed to be a contributing factor.
Just ordered the PC. Hopefully this fixes or helps that issue.
Have this exact thing as well but with the Colorado but I've noticed it all year. Seems like a lot of us are having the same clunk. When my wife is in the truck she looks at me like "WTF" is wrong with your truck. Getting close to taking it to the dealership but the one in town is so slow and awful I may need to take it out of town. Do you guys happen to have the TSB numbers that are associated with this issue so I can bring it up to the dealer. Really annoying stuff.I now have this on a 17 Canyon with 6k miles. Didn't notice the shudder during the winter when temps were <30 degrees, but now I'm noticing it quite frequently in 40-60 degree weather. I too have the hard "clunk" in low gear, 1-2 and 2-1 usually, and always when shifting from Park to reverse each morning after it has been parked all night.
Do we think the shudder is "bad" for the TCC/Tranny, or just a nuisance? My warranty is void due to branded title so at this point in time I'm not interested in spending >$500 to pay a dealer to flush the fluid 3 times.
Did they put trans reprogramming on the paperwork? That takes time, which they want reimbursement for, so it's logged on your paperwork. The flush is the fix, so it will seem different, because it's shifting correctly.Took mine into the dealer today (2017 Canyon Denali) - ~7800 miles -- for an oil change, a door rattle issue (2nd request) and the shudder/rumble issue. Shudder started about 2,000 miles ago, and has noticeably become evident the more I drive it...probably since I know it is there
Dealer followed the TSB -- flushing 3 times, etc -- so we will see if it helps. I think they also reprogrammed the transmission, as it seems to be "different' on the way home.
Now if I could actually get them to fix the door rattle- 2nd time it has come back as no issue found...sigh.
The advisor said they flashed it - but the paperwork isn't descriptive other than listing Fluids...Thank you
Door rattle? Loose screw floating around in the door or bass speaker type vibration?
The TSB # that I was given is: 16-NA-175 The Document ID is: 4526930 from http://gsi.ext.gm.com I think only service shops can access it.Have this exact thing as well but with the Colorado but I've noticed it all year. Seems like a lot of us are having the same clunk. When my wife is in the truck she looks at me like "WTF" is wrong with your truck. Getting close to taking it to the dealership but the one in town is so slow and awful I may need to take it out of town. Do you guys happen to have the TSB numbers that are associated with this issue so I can bring it up to the dealer. Really annoying stuff.
Edit: I see this one: #16NA019, THIS TECHNICAL BULLETIN PROVIDES THE PROCEDURES TO COMPLETE A TRANSSMISSION ADAPTIVE LEARN ON ALL THE DIFFERENT TYPES OF VEHICLES AND TRANSMISSIONS BASED ON RPO OPTIONS TO CORRECT A CONDITION OF HARSH SHIFTS ON HARD ACCELLERATIONS.
That is similar but its not happening on hard accelerations, its happening on all accelerations, and letting off the gas, and usually at random.
