I'll take the tomatoes... if the brochure I found is correct and there is a difference between Remote Keyless and Keyless Open / Start.. the WT and Trail Boss "have to" use their remote to get in, while the rest of us don't have to touch the remote at all in most cases, especially if you turn on passive locking. If I had a trail boss, I think I would cut a key as a spare.
Why would you need a spare key? There is one in the fob. If battery dies use the lock cylinder and lay the remote in pass side cupholder to start
Passive locking and the button on doors are two different things.
Passive locking the doors lock themselves after last door is shut. It is turned off and on thru infotainment center
Keyless lock/unlock is the button is turned on and off with remote
Disabling Keyless Unlocking:
With the vehicle off, press and hold lock and unlock on the remote key at the same time for approximately three seconds. The turn signal lamps will flash four times quickly to indicate access is disabled. Using any exterior handle to unlock the doors will cause the turn signal lamps to flash four times quickly, indicating access is disabled. If disabled, disarm the alarm system before starting the vehicle.
Enabling Keyless Unlocking:
With the vehicle off, press and hold lock and unlock on the remote key at the same time for approximately three seconds. The turn signal lamps will flash twice quickly to indicate access is enabled.
